Not firing and blowing 20a power train fuse
Have 1995 250 heavy, 7.3 turbo diesel 4x4, just finished installing a new torque convertor and was blowing fuse marked 9 it's a 20a and truck would turn over and not fire, battery also had low cranking even after charge. Have ordered new heat plate for fuel bowl but was stilling blowing fuse after disconneting wire to heat plate at spade connection. So then unplugged all wiring harness to tranny as was recently removed for tc replacement, and had wait to start light come back and not blowing fuse, then during reinstall of wiring harness fuse went again at key turned on but not turning key for crank over. So then had passenger side wiring harness on tranny checked at ford and was good, they said check main feed harness, which will happen tommorw.
But am looking for other feedback and input on my dilemma ....thx
Edog
Edog
So, have traced to a ground wire that was connected to transmission has current of 12v disconnect ground and truck starts no fuse blow. But now only 1st and 2nd and reverse work, when in drive truck drives slowly off start and od light flashes.....?.....is there something electrically wrong with my tranny ? Or a solenoid gone in my tranny...help
BretE
05-28-2012 11:17 AM
dtperformance
11-11-2011 09:10 PM
