Sponsored by: Real Truck
Blown fuses
Old Apr 14, 2006 | 03:38 PM
amudman's Avatar
amudman
Blown fuses
I have a 2003, F-350. I keep blowing fuse # 22, which is the engine control fuse. Does anyone know what could be causing this. Thanks
Old Apr 14, 2006 | 04:28 PM
wlihntr's Avatar
wlihntr
could be your fuel filter bowl heater is shorted out, try unplugging it (at the bowl) and see if that helps
ps. if its a diesel
Old Apr 14, 2006 | 04:46 PM
wlihntr's Avatar
wlihntr
also check the wiring harness to the IPR (front of drivers side fuel rail on top of the head) and the main engine wiring harness that runs over the drivers side valve cover for shorts from them rubbing against things...again if its a diesel
Old Apr 14, 2006 | 07:37 PM
amudman's Avatar
amudman
Thanks Wlihntr..I checked all the wiring. I unplugged all three plugs from the heater. turned the key on, blew the fuse. I unplugged the mass airflow sensor and turned on the key, blew the same fuse. Anymore suggestions would be very helpful. Thanks
Old Apr 14, 2006 | 09:24 PM
99f350sd's Avatar
99f350sd
So its a gas engine?
Old Apr 14, 2006 | 10:22 PM
amudman's Avatar
amudman
No, It's a diesel
Old Apr 14, 2006 | 10:53 PM
99f350sd's Avatar
99f350sd
Ya heater dah..
