hey guys... so im getting ready to do my dpf/cat delete.... I have a sct livewire and a MBRP cat/dpf delete pipe... so instead of taking the existing exhaust sensors out i figured i would just buy all new ones and leave the old ones in the stock set up.... i was wondering if anyone knew the part #'s for all the sensors or if they are all the same part #....thanks for the help!!
from what i understand the sct livewire needs the delete pipe with the bungs and the sensors present... so what im saying is that instead of trying to get the existing sensors out of the existing exhaust and risk breaking them...i would probly rather just buy all new sensors for the delete pipe so that every year when it came time for state inspections i could just swap the exhaust piping out and plug the sensors into the harness without having to remove the sensors each time.... new england winters can make backing things like nuts and bolts and such out quite a challenge!
They only need to be plugged in huh?...i thought i needed a delete pipe with bungs for the sensors????... im near boston...im originally from roslindale but i now live in dedham
I want to delete my CA. cat bad. But there are sensors before and aft.
There are no inspections in my county so I only seek to avoid honking up the program by deleting/pounding out the cat.
