Power steering flush??????
If it smells burned, and is very dark, you can certainly change it. There is no recommended mileage or time period as the fluid is under light load the high majority of the time. If it gets overheated, it can break down and provide less lubrication, I believe. There is no contamination as you would have in the oil sump, much like the transmission has no external source of chemicals to break down the ATF. Just heat and the shearing of normal oil life.
tom
tom
abyars111
04-16-2013 05:36 PM
Sugarbooger
11-15-2007 01:19 PM
BigClint
12-05-2004 03:39 PM
