Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Power steering flush??????
Old 07-14-2012, 08:10 PM
daveya48187's Avatar
daveya48187
daveya48187 is offline
does the power steering fluid ever need to be changed? the owners manual doesn't require it. I've got 140,000 miles on my 2002 escape with the original fluid in it. there's no problem with it but how far can you go on the original fluid?
Old 07-15-2012, 07:22 AM
tomw's Avatar
tomw
tomw is offline
If it smells burned, and is very dark, you can certainly change it. There is no recommended mileage or time period as the fluid is under light load the high majority of the time. If it gets overheated, it can break down and provide less lubrication, I believe. There is no contamination as you would have in the oil sump, much like the transmission has no external source of chemicals to break down the ATF. Just heat and the shearing of normal oil life.
tom
Old 07-15-2012, 08:51 PM
bmuhlbach's Avatar
bmuhlbach
bmuhlbach is offline
I have a vacuum pump I bought for doing brakes.I used it to take the old fluid out of the reserver and refilled it with fresh fluid.There was no issue but the fluid was dark in color.
abyars111
04-16-2013 05:36 PM
brc777
1983 - 2012 Ranger & B-Series
04-01-2012 06:57 PM
Sugarbooger
11-15-2007 01:19 PM
BigClint
12-05-2004 03:39 PM
Metacarpels
1997 - 2003 F150
11-28-2004 09:47 PM
Quick Reply: Power steering flush??????
