Yanked my K&N Drop-in Filter…pinging fixed
You regulars will maybe remember my mileage report from last month. I was surprised that my K&N filter didn't provide any measurable MPG increase given that the truck "felt" more open during WOT runs. I knew it was time to pull and clean the filter, so I started thinking of going back to the stock paper filter just because of the increased filtering capacity.
Then I started wondering about the heavy pinging I got sometimes during high RPM runs while pulling my trailer. This was a new phenomenon this year and I realized it only started happening since I put the new K&N in. The pinging was constant and pretty bad once I got up near 4,000rpm. The computer didn't do a very good job of controlling it, so I always had to back off the throttle to find the sweet spot. I decided to pull the K&N and put a stock filter back in. Last weekend I made a run up the mountains with the trailer and it included a couple of high-RPM sprints. Not a single pinging issue and the truck felt better pulling the heavy load (which makes sense…I was staying in the throttle and all 10 cylinders were firing on schedule).
So…the K&N went into the garbage. Not sure why the computer couldn't adjust to the increased airflow, but it didn't...
The inside of my intake also had a very thin layer of dust on it. But I know the service idiots left the intake assembly unlatched when they were finished working on my truck about a year ago (a few months before I got the K&N). I didn't discover it until I went to install the K&N, so I'm not sure where the dust came from.
I can tell you everything is clean now!
I think the only obvious reason to switch back is if you're in a dusty environment. While everyone's results may vary, I think everyone agrees/knows the increased air flow comes at the cost of filtering.
I've always had great luck with K&N drop in filters. Never used a cold air intake before and I'm not really looking to get one. But the K&N is a lot of maintenance, which isn't something a lot of people don't wanna do and I don't blame them. It's a pain when u do it every oil change like i do
Denny
