I need two sheets of metal one 20" by 17 and one 20" by 12". its for a truck floorboared im not sure what type or size of metal i should use for this. Any help? prices?
For that floor pan does it go under the seat cause the metal there is perfectly fine. I just need from the seet to the fire wall area
I don't think they are that long but the idea is to use what you need, your going to remove rusted material until you get to solid floor that you can weld to then trim the new panel to fit while keeping it as neat as you can.
