Rear Suspension Re-Build Issues - Help wanted
Old 07-07-2012, 09:38 PM
52 Ford F1's Avatar
52 Ford F1
52 Ford F1 is offline
I cannot seam to figure out how to get the front bushings out of the rear suspension on my 52 ford F1. Has anyone done it before? What are the tips/tricks?
The whole point of me doing this is really to repair some frame rot by the front shackles. To get extra room to weld I decided to switch out the pins and bushings as well. The rears took a torch and plenty of hammering... but in the front, the frame holes do not allow for hammering as easily...
Any help would be appreciated, I am switching out the shocks, and removing a few leafs at the same time, so any pointers would be great.
The U-bolts can apparently only be bought from suspension shops?.?.?. Does anyone know of a good chain or shop in NKY to find them?
Anyone in the Cincinnati, NKY area, I am looking for help and would be more then willing to pay to learn.
Old 07-07-2012, 09:46 PM
Harrier's Avatar
Harrier
Harrier is offline
I think most people drill a hole in the crossmember to get access to the hole. In 53 they wised up and put the hole in there for you.
Here are some threads discussing this topic that should be very helpful.
https://www.ford-trucks.com/forums/1...r-springs.html
https://www.ford-trucks.com/forums/8...g-removal.html
Old 07-07-2012, 11:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Every truck spring shop around here makes their own U-bolts while you wait. From past experience, I always take the spring plate along and have them make sure the new U-bolts will go thru the holes -- they are a real pain to squeeze or spread!
The only thing I don't like about these made-to-order U-bolts is that they are round stock all the way around the axle. I'd prefer the OEM-style that are flattened where they go around the axle tube. Just seems less likely to crease the tubes.
1 Excursion camper
04-03-2014 01:48 PM
Bonkrr
1997 - 2003 F150
09-14-2009 10:19 PM
57phil
02-21-2008 11:26 AM
orange peel
10-11-2002 06:08 PM
fatdaddy
08-02-2002 12:13 AM
Quick Reply: Rear Suspension Re-Build Issues - Help wanted
