Front Suspension
Front Suspension
Hay there guys, here With another question I replaced the rubber doughnut at the end of what I believe is called the torsion bar,its the bar that connects to the chassis and the I beam right under the coil spring,please correct me if I am wrong any ways I have knowedest that my tires are wearing out on the outside edge,my question is did I run my truck out of aliment wen I Took the torsion bar of to replace the rubbers, king pins are tight no play there if so do I take it to a regular aliment shop to have it fixed, or to a big rig shop please help oh almost forgot tires squeal wen I turn thanks in advance.
If in correct the rubber doughnut is the insulators on the very ends of the radius arms. And the beam under the coils and and on the inside of the shocks are the actual i beam axles. Twin i beam if you have 2wd and solid i beam if you have 4wd.
Im guessing its a 2wd.
Other than the squeeling and tires wearing down any other problems? Does it track straight?
About the wearing down are you sure its only on the outside edge? You might have incorrect toe-in, under inflation or your misalienged. So most likely its what you said. Misaligned from having the radius arm off. To correct that you'll need help from someone other than myself.
Just my 2 cents. Hope it helped! Good luck.
--lil Smokey--
--lil Smokey--
Radius arm bushings should always be replaced as sets - that means all four, two per radius arm.
If you're wearing the outside of the tire, that's excessive positive camber or too much toe. If it were a tire pressure issue, over-inflation would wear the middle more that the tire's shoulders. Underinflation would result in both shoulders wearing faster than the middle.
Thanks for the quick response guys and for correction on the name of the part, Lilsmokey yes the truck track pretty straight and my tires have 50psi out of 80psi. 80psi bean the maximum ,Hio silver I did replace all 4 insulators, so will an aliment fix the problem,regular auto shop or do I have to take to a big rig shop.
Caster and camber are built into the beams from the factory. If for some reason they need to adjusted, they have to be heated and tweaked to the correct caster and camber. Most likely it is a toe in-toe out issue. A regular shop should be able to do it for you.
Did you check the bushings where the beams pivot? Some times these get worn out also.
are you talking about the bushing where the beam starts at the opposite end from the wheel,or the bushing for the spindle.
Now am I causing this problem by lifting the truck from the beam just a couple of inches to the side of wheel so I can put a stand for wen I work on breaks or change tires please tell me I am not the one to blame
iLooknasty
18
03-11-2016 07:01 AM
paulwjax
09-09-2009 01:05 PM
Rcmgiasson
09-22-2002 06:01 PM
