Alignment??
Old Feb 25, 2009 | 09:12 PM
vettman's Avatar
vettman
Alignment??
Just finished replacing radius arm bushings on my '76 F350, supercab, 460; do you think I should have the alignment checked? Is toe-in the only parameter that could have changed?
Thanks
Old Feb 25, 2009 | 09:40 PM
frigerator's Avatar
frigerator
If you think you should get it checked then I'd do it. If you start to wear out your tires your the one to buy new ones. If it has been more than a year since the last one it sure wouldn't hurt. You could always take a tape measure and measure across the front of the tires and then the back of the same tires and see if there the same distance.
Old Feb 25, 2009 | 10:29 PM
ken selvy's Avatar
ken selvy
Toe in is it on our trucks and bending the beams for camber is it . Radius bushings helped the cupping on my tires . Good luck .
