1969 Ford F100 Project
Hi I'm new to this. I have a 1969 Ford F100 with a 390 in it, the problem with it is the 390 had a blown head gasket and the engine sat for 15 years. I'm restoring this truck to be my sons truck as I am only the second owner. I'm thinking of doing an engine swap with a newer engine maybe a 5.0 fuel injected. I would like some ideas on this as to what I should do. Thank you
Assuming your son is young I would take the time & do the modern swap. Here is the problem as I see it. When we all die there will be so very few who know what to do with 1 of these dinosaur engines, parts will be expensive & very difficult to find. Doing a late model 5.0 or 4.6 (while neither anything I personally would want) swap correctly with all on board systems should be something he could take to any shop & have worked on relatively easily. The only difference would be it is wrapped in old skin. Don't forget to wire in the connector for diagnosis.
Think about what things will be like 20yrs from now when balanced against today & 20 yrs back. A modern swap will still be a dinosaur at that time but at least more like what people know. Of course you also have the purest approach.
knmealer93
17
07-08-2014 09:48 AM
sampatton
04-04-2007 01:30 PM
