Hydraulic clutch
I went through that a few months ago on mine if it has the same quick disconnect type fitting you will need to very carefully remove the clip inside the connection part on the slave cylinder tube going into the trans and bend the little fins in towards the center where the line connects and reinstall it. Then make sure to press the line in straight and it should click right in. Hope this helps I had to buy a new line before I figured out that was not the problem.
Dre82s
11-15-2010 08:19 PM
plapczynski
12-11-2008 12:59 AM
