Hydraulic clutch
Old 06-23-2012, 02:41 PM
GillisB93's Avatar
GillisB93
GillisB93 is offline
Hydraulic clutch
I put a new clutch kit in my 99 f-150 with the 4.6. It came with the clutch disk,pressure plate and throw out bearing. i got the tranny back up in but now my Hydraulic line will not connect into the slave cylinder. Its still the same one that was in it. any help
Old 06-24-2012, 05:31 PM
54FordF1shortstep's Avatar
54FordF1shortstep
54FordF1shortstep is offline
I went through that a few months ago on mine if it has the same quick disconnect type fitting you will need to very carefully remove the clip inside the connection part on the slave cylinder tube going into the trans and bend the little fins in towards the center where the line connects and reinstall it. Then make sure to press the line in straight and it should click right in. Hope this helps I had to buy a new line before I figured out that was not the problem.
Uncle.$am
1983 - 2012 Ranger & B-Series
11-08-2018 09:25 PM
dodgewade
12-05-2016 05:08 AM
Dre82s
11-15-2010 08:19 PM
plapczynski
12-11-2008 12:59 AM
kmvangelo
09-03-2007 09:31 PM
Quick Reply: Hydraulic clutch
