Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 06-22-2012, 12:06 AM
vincepro911 vincepro911 is offline
1994 Ford F-150
vincepro911 is starting off with a positive reputation.
5 speed automatic tranny???
I purchased a 1994 f150 xlt 4x4 off road truck, it only had 94xxx miles and it was 18 years old. well I assumed it had an e40d transmission because the vin was an e code. as i was driving i counted the shifts and I counted five. one more than the e40d was supposed to have. soon after purchasing the truckI replaced the transmission pan seal and filter. The pan wasnt shaped like normal transmission pans but i still found a seal and filter that was marked 1994 obsolete in the database. Im totally confused on what transmission I have in my truck can anyone help?
  #2 (permalink)
Old 06-22-2012, 02:05 AM
muscletruck7379's Avatar
muscletruck7379 muscletruck7379 is offline
1984 Ford Bronco
muscletruck7379 has a good reputation on FTE.muscletruck7379 has a good reputation on FTE.
maybe your feeling the torque converter lock up.
__________________
1973 f250 highboy 4x4
1984 full size bronco, -DIS, wide band megasquirted 300 and np435 w/ dual range aux tranny on the way! - finally updated! 12/29/2011
1988 f150 extended cab 4x4, mostly stock.
1984 mercury capri, 5.0 conversion, my little monster...
1961 ford falcon, all stock, in family since '68
  #3 (permalink)
Old 06-22-2012, 07:13 AM
Conanski's Avatar
Conanski Conanski is offline
1990 Ford F-150
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Yes that's the TC lockup you're counting as a shift, Ford does have a 5-speed auto but it didn't even exist until well into the next centuary after this truck was built and it's not compatable with the engine family in your truck so there is no way someone could have swapped one in.
__________________
Paul (Conan) O'Brien
1990 5.0HO AOD XLT X-Cab F150 3.55LS, 1990 2.3L 5-sp Ranger 3.08, 2004 3.0L 5-sp X-cab Ranger Edge 4.10, 2004 2.5L 5-spd Subaru Legacy
1996 Kawasaki ZX11D, 2004 Honda 599, 2008 Kawasaki KLR650
  #4 (permalink)
Old 06-22-2012, 07:54 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
Diesel Junkie
1993 Ford F-250
FORDF250HDXLT is a splendid one to beholdFORDF250HDXLT is a splendid one to beholdFORDF250HDXLT is a splendid one to beholdFORDF250HDXLT is a splendid one to beholdFORDF250HDXLT is a splendid one to beholdFORDF250HDXLT is a splendid one to beholdFORDF250HDXLT is a splendid one to behold
you are counting the lockup as a gear change,however you still only feel 4 transitions because D already = 1st gear which you will not feel it shift into.
what you'll feel is this:
place selector in D........you'll feel the trans shift for the first time.that will be 1-2.you'll feel it shift again from 2-3.you now felt 2 shifts,but your in 3rd gear see?
next you'll feel lockup.now you felt 3 transitions.2 shifts and a lockup.your now in a much more advanced state than a old C6 trans known as 3rd lock (3rd gear,with a locked up converter- a direct connection between engine and trans.a direct internal clutch of the converter-same state now as a manual trans)
lastly you'll feel the trans shift from 3rd lock,into the trans economy gear; 4th also known as OD.this counts a total of 4 shifting transitions felt.3 actual shifts felt and lockup of the converter.
at no time will you feel as if the E40D is a 5 speed trans..........unless your still lost about the converter,because under load you will notice the converter unlocks and remains unlocked during a downshift for increased rpm pulling power.the duration of which is load sensitive.still doesn't account for your incorrect 5 shift counts on take off though,so try again.
axle code E = E40D.the pan reads: metric.
__________________
'93 BRG/BLK F250HD XLT 4x4 1st Gen Navistar 444ci Diesel w/ Intercooled 2nd Gen Banks Sidewinder Turbo, Built E40D, Hydroboost Brakes, Dually, Dump, & Plow
  #5 (permalink)
Old 06-22-2012, 02:25 PM
jroehl jroehl is offline
Garage is empty, add now
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
Just so there's no confusion, the transmission code is listed under "TRANS" or "TR", and is "E" for an E4OD. "Axle Code" is something different.
Jason
__________________
-2003 E250 cargo 4.2L V6, 4sp electronic auto, 22 axle (work van)
-1993 F250 XLT xcab LB 351 2wd E4OD 4.10 open (parked, tranny issues)
Probably the greatest harm done by vast wealth is the harm that we of moderate means do ourselves when we let the vices of envy and hatred enter deep into our own natures.
Theodore Roosevelt
Tags
ford, tranny
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
