Help identify my rear axle
I know by the tag on the front axle I have 3.73 gearing and since I'm a jeep nut I know its a Dana 44. But I need help identifying the rear end on my '00 250. It has 12 bolts so I know its a Dana 50-80. Since I don't know how to post pix I'll just post what's on the rear axle tag. Can anyone tell me if its a LSD or not.
3 S 138 H
73 10 5 0C07
I've found the post about axles decoder for the door sticker but mine is blank showing the axle code. But its also showing the ext paint code as UA, Excursion ebony on my 250!
3 S 138 H
73 10 5 0C07
I thought I responded to this but I must've missed a button somewhere.
I don't know about the rear axle tag. Look at the certification label on the door and compare it to the tech folder (link at the top of this forum) for the axle code. It will tell you what gears and if you have limited slip.
Also, according to the door sticker, my 40/20/40 front seat is Captains chair seats!
true, but most of the higher end gear lubricants already have the modifier in them.
Sterling 10.5 axle - Wikipedia, the free encyclopedia
on
No, you have a Sterling 10.5 differential. The 10.25 was the predecessor to the 10.5 and isn't quite the same.
thats a nice little article too. explains it simply.
bryan_johnson
11-04-2007 05:44 PM
Kyle460BigBlock
08-29-2007 10:19 AM
