Rear End ID
Old Mar 26, 2005 | 08:35 PM
morrigj83's Avatar
morrigj83
Rear End ID
I have a 92 F-250 4x4 5 spd. I believe that the rear end is the ford 10.25 but im not sure. I first thought it was a dana 60 but that was wrong it is some rear end made by ford or specificly for ford by someone else. Im trying to find gears for it but need to know what axle first. If anyone knows please let me know.
Old Mar 26, 2005 | 08:57 PM
95X15's Avatar
95X15
Look under axle code on sticker on door and post - we will try to identify from code and axle rating. Also check for a tag on axle probably under one of the bolts. In 95 manual axles to 8250# are built by Ford, 11000# axle is Dana, limited slip axles are built by ford and start with a letter.
Old Mar 26, 2005 | 11:07 PM
Monty06's Avatar
Monty06
how many bolts do you have on the diff cover?
Old Mar 26, 2005 | 11:09 PM
2Wise4aGM's Avatar
2Wise4aGM
It is a 10.25.
Old Mar 26, 2005 | 11:50 PM
Monty06's Avatar
Monty06
what is the axle shaft diameter?
