Help ID front Axle
Old Jan 28, 2005 | 06:05 PM
farlight7's Avatar
farlight7
Help ID front Axle
1989 F250 4x4
On the door post the axle code is B5
on the front differential tag is:
4 D9 VE8TA UG (last two are ?)
V6(or 5)1031 F-2
but both the V's look more like triangles, not letters.
Thanks, Dave
Old Jan 28, 2005 | 06:08 PM
andym's Avatar
andym
If you post your front GAWR it will make it easier to tell if you have the Dana 44HD or the Dana 50.
Old Jan 28, 2005 | 07:35 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Axle code 'B5' is a 4.10 limited slip, 5300 lb Ford rear axle, which is a 10.25" Sterling semi-float.
Having a semi-float rear axle, the truck would be a light-duty F250, so I would think the front axle would be the Dana 44HD rather than the Dana 50.
Someone may be able to translate the codes from the front axle to be certain, or you can look for the Bill of Materials number on the axle, which is a 6 or 7 digit number with no letters in it, usually stamped into the axletube not far from the differential housing, at least on straight axles anyways. You can take this BOM number and go to the Dana website for light duty truck axles www2.dana.com/expert, and look up what axle it is.
Old Jan 28, 2005 | 10:01 PM
farlight7's Avatar
farlight7
don't the semi-floating axles have the beer-can extensions at the wheels?
my truck doesn't have.
Old Feb 22, 2005 | 01:53 PM
crazandy's Avatar
crazandy
Thats the full floaters. Semi-floaters stop flush at the wheel mounting surface, full floaters stick out about 5" or so.
RIDE RED
Modular V10 (6.8l)
Dec 17, 2023 09:57 AM
2010F150Platinum
2009 - 2014 F150
Oct 7, 2010 10:11 PM
Dave Sponaugle
West Virginia Chapter
Dec 28, 2007 06:34 PM
dave186
Jun 7, 2001 10:25 PM
