dash pad over glove box
Old 06-20-2012, 11:38 AM
crossy's Avatar
crossy
crossy is offline
short of getting lucky enough to find a good used one- what are the options for replacing -or covering -the cracked ,mini dash pad found in the 92-96's? is it available new, ? dark gray? thanx , crossy
Old 06-20-2012, 12:34 PM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
I don't think that LMC carries them, but I think I might have one that is in fairly good shape if your interested. Not sure what they are worth tho.
Old 06-20-2012, 12:37 PM
crossy's Avatar
crossy
crossy is offline
hit me at TRUXGUY AT YAHOO.COM with a price. I don't even know yet how hard they are to get off, LOL- thanx, Crossy
Old 06-20-2012, 01:01 PM
strokin'_tatsch
They are really easy to remove and install. Pull the radio and pull the glove box. You will see some little nuts holding it on from below. Just pull the nuts off and the pad lifts off. When I get home tonight I'll get the grey pad off the shelf, clean it up, and send you a pic to make sure it matches. I think it had one tiny crack in it, but I'll check and send you an email.
Old 06-21-2012, 05:31 AM
rob6095's Avatar
rob6095
rob6095 is offline
It's hard to judge what these are worth. If you look around you can find them fairly cheap if someone just wants to get rid of it. I've seen them run up to $125 for a perfect NOS one and less for used ones with issues. LMC makes a cover that goes over the whole dash but not that individual piece. When you get your new one hope it has some of the nuts on it because you will probably drop some of yours when you're taking it off but other than that it's an easy swap.
Old 06-21-2012, 09:29 AM
crossy's Avatar
crossy
crossy is offline
Knowing it's easy helps a lot. I hit many U-pulls when I'm 'hunting' and this 93 needs quite a few Yard parts ,so i think I'll start a list before i pay the big bucks. thanx, crossy
petrokiller
13
09-14-2013 07:49 AM
Red Cobra
07-25-2010 01:58 PM
fordtough05
02-04-2010 08:32 PM
fyrfytr
10-24-2007 12:32 PM
holl
03-25-2001 02:26 PM
Quick Reply: dash pad over glove box
