dash pad
Old Feb 2, 2010 | 03:53 PM
fordtough05's Avatar
fordtough05
dash pad
i haven't even tried to remove it yet because i bought a junk truck with a perfect dashpad and i dont want to ruin it. do the screws on the top have to come out or does it just pop off?
Old Feb 2, 2010 | 04:03 PM
ford1977owner's Avatar
ford1977owner
you have to remove ur gauge cluster radio and glove box and take i think 6 screws out...correct me if im wrong
Old Feb 2, 2010 | 04:09 PM
78workhorse's Avatar
78workhorse
There is about 12-15 nuts that hold the pad to the dash. Youre going to have to take inst. cluster and glove box out to get to them all. Ive taken 4 out and installed 2. Its a little frustating and cramped but Im glad I did it. Not the hardest thing to do.
Old Feb 2, 2010 | 04:14 PM
ford1977owner
i was only going by what i was told never did it before...thanks for the correction 78workhorse
Old Feb 2, 2010 | 04:16 PM
droppedf100's Avatar
droppedf100
The screws on the top do not come out. All the nuts are underneath the pad. I had to remove the cluster, head unit and glove box. Dont yank on it bc you probably missed a bolt if its not budging.
Old Feb 2, 2010 | 05:13 PM
Customcab's Avatar
Customcab
Theres ten (3/8 or 5/16 )hex / crown type nuts holding the pad on; all are access as you guys mention. You will even have to remove/lossen the duct work if you have a A/C dash. All the nuts face downwards towards the floor except one nut dead between the radio facing & glove box door; if I remember right. I recommend removing your old pad and then remove the other one; that way you have a layout of the bolt position and havn't damage your good one. Also if I recall they run in pairs; like two to the side of the dash bezel; then two opposite side of the bezel; glove box the same and two center as mention between radio & glove box door facial. I use a 1/4 6 point socket set; both deep well & regular.
Hope this helps.
Mitch
Old Feb 2, 2010 | 05:22 PM
Shane in WI's Avatar
Shane in WI
There is also one nut facing the front of the truck in the center of the dash pad. Once you see how they come off, it's not so bad. The screws from the top hold the metal dash not the pad. Took me forever to figure it out in a junk yard last summer. Cut up my arms pretty good, but did get a nice dash pad for $30.
Old Feb 2, 2010 | 06:20 PM
fordtough05
good thing i checked, i probably would have tried to snap it off.... thanks for the help
Old Feb 3, 2010 | 08:21 AM
DeepRoots's Avatar
DeepRoots
along the same lines.....
has anyone bought/or seen one of the "dash pad covers" that LMC sells?
Old Feb 3, 2010 | 08:42 AM
droppedf100
I bought a coverlay one from JC Whitney to use but I found a clean pad in the junkyard so I used that instead. It fit pretty well. Ill sell it to you
Old Feb 3, 2010 | 04:50 PM
DeepRoots's Avatar
DeepRoots
I just looked at jc whitney, they don't have a picture.
Can you take a picture of it?
and lets take this to pm, I don't think fte is much for dealin in public.
Old Feb 4, 2010 | 08:32 PM
77460ford's Avatar
77460ford
I have a pulled dash on the floor, I can take some pics to show the location of the dash pad mounting points if you like.
