Please Help Installing My New Side Trim
it is just that when I try to slide the trim down the edge of the sheet metal onto the clips, it pops off before I get it completely to the end. You have to raise the end when you come to each clip just a little and that has been enough to pop off the trim from the preceding clip. I don't know if I'm explaining it very well, but I just hoped maybe someone could tell me which piece to start with or which end of the sheet metal to start sliding it from because it apparently makes a difference.
Thank you for the tip! I will most assuredly try this tomorrow. That would MUCH simpler than the way I had been trying. Thanks again.
fishnative
12-18-2012 06:55 AM
71_4x4_390
07-23-2003 08:28 PM
