Cab Switch 57 on a 60?
Old 07-25-2012, 10:11 AM
cbutcher's Avatar
cbutcher
cbutcher is offline
What are the deferences, if any, between the two years?
There is one listed on CL that looks to be cleaner than my rust bucket.
Thanks
Craig
Old 07-25-2012, 02:25 PM
a4t1rat's Avatar
a4t1rat
a4t1rat is offline
They are the " Same " I will tell you that there is a differance in the wireing coming out of the cab. i have a 57, 58, 59 and a 60. and for the most parts they are the same.
Old 07-25-2012, 02:39 PM
manglass's Avatar
manglass
manglass is offline
I'm not aware of any differences in the light truck (F100-F350) cabs that would prevent you from swapping them but I've never actually done it. The only difference I remember seeing is that some of the larger truck (e.g. F-750) cabs had an access panel in the passenger's side floor for the battery. Those might have other differences I don't know about.
Lou Manglass
Old 07-25-2012, 02:50 PM
manglass's Avatar
manglass
manglass is offline
Good point "a4t1rat." Your 1960 has a fuse box, the 1957 does not. There may be some differences there and where the harness exits the cab but nothing that can't be "adjusted."
Lou Manglass
Old 07-25-2012, 06:09 PM
spurredon's Avatar
spurredon
spurredon is offline
You will prolly want to yank the whole harness out anyways. Great time to look it over. None of the wiring is specific to the cab. As long as you switch all the doo-dads as well, you will be fine. I used a '59 F500 for a parts vehicle and that was identical to add to what manglass what saying!
Old 07-26-2012, 02:44 PM
Romak's Avatar
Romak
Romak is offline
if you pick up the 57 for parts and only plan to use the cab let me know. i might be interested in the front clip to recoop some of your moneys.
Old 07-27-2012, 12:08 PM
cbutcher's Avatar
cbutcher
cbutcher is offline
Found just a cab in Placerville, trying to get up there to check it out.
Warren81
16
11-04-2016 07:36 AM
cbutcher
07-13-2011 10:59 PM
kashmcoll
07-15-2010 12:12 AM
harley f150
04-05-2009 08:37 AM
oilyowl
08-12-2005 08:57 PM
Quick Reply: Cab Switch 57 on a 60?
