57-59 cab interchange?
Old Aug 5, 2005 | 08:30 PM
oilyowl's Avatar
oilyowl
Hi all
As i am not familier with the 57-59 trucks, I have a question.
I have a cab from a 57 f-600, would that cab be the same, or fit a 59
f-100 ?
Thanks in advance
Oilyowl
Old Aug 5, 2005 | 09:26 PM
Sixoh's Avatar
Sixoh
Howdy -
Yes, the cab is the same. The fenders, grille, hood and front pan are all different from the '59 and '60 models. You can use the cab and your old front she et metal together to make a new '59!
Old Aug 5, 2005 | 11:19 PM
mr4speedford's Avatar
mr4speedford
My only thoughts are the wirring holes in firewall by the master cyl, I think 57/58 was different for 59/60. I think.... -4speed
Old Aug 6, 2005 | 12:06 AM
WillyB's Avatar
WillyB
59 and 60 have different wiring holes - have one of each apart in my work area. Don't know about the 57/58s.
Also, the 60 had electric wipers, the 59 has vacuum - don't know the differance in the cabs between the two.
Old Aug 7, 2005 | 12:48 AM
kooper909's Avatar
kooper909
'60 still had vacuum wipers as standard equipment.
Old Aug 7, 2005 | 06:21 AM
StarFox's Avatar
StarFox
I've got vacuum wipers on my '60... Fox
Old Aug 7, 2005 | 08:39 AM
WillyB's Avatar
WillyB
I guess they could have been changed - but my 60 custom cab has electric and the switch assembly looks stock, as does the wiring.
Old Aug 7, 2005 | 09:18 AM
mr4speedford
all V8's had electric, six cylinder's had vacuum wipers unless optioned with electric. -4speed
Old Aug 8, 2005 | 12:13 PM
oilyowl's Avatar
oilyowl
Thank you all,
the info is greatly appreciated
Oilyowl
Old Aug 12, 2005 | 02:09 PM
niteowl's Avatar
niteowl
57-60 Differences
For what it's worth, I have a 60 that came with vacuum wipers.
Mine is an early production run 60 though and it came with a 59 style hood.
So the year cannot be the absolute indicator of the differences as there was a bit of crossover.
I think the 59 hood combined with the 60 nose is the best combination they made. Just wish I had not ended up with those damned vacuum wipers. I have since replaced them with electric but it was EXPENSIVE.
Old Aug 12, 2005 | 04:57 PM
kooper909's Avatar
kooper909
For how long did they use '59 hoods on the 1960 trucks?
Old Aug 12, 2005 | 06:04 PM
mr4speedford
Are you 100% sure its original? only f-700+ used the old style hoods. -4speed
Old Aug 12, 2005 | 08:57 PM
niteowl's Avatar
niteowl
59 hood on a 60
No way to be absolutely certain but I have heard from several sources that the 59 hood carried over on 60 models manufactured in 59. I have seen pictures of a couple 60's with the 59 hood as well.
Damifiknow
Jan 3, 2014 05:47 PM
f100project
Mar 19, 2007 01:08 AM
Randy Jack
May 18, 2005 03:49 PM
oilyowl
Oct 8, 2003 07:41 PM
mtflat
Dec 26, 2002 03:18 PM
