Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1987 - 1996 F150 & Larger F-Series Trucks 1987 - 1996 Ford F-150, F-250, F-350 and larger pickups - including the 1997 heavy-duty F250/F350+ trucksSPONSORED BY:
  #1 (permalink)
Old 06-13-2012, 02:08 AM
drjoe171 drjoe171 is offline
Garage is empty, add now
drjoe171 is starting off with a positive reputation.
1989 f250 351 windsor PCV valve
I do wish this was a joke but neighbor knocked the pcv
valve and hoses off trying to replace the vacuum line to the transmission.
All I have to look at is a pcv valve and a couple inches of vacuum line.
He said he dropped something under the intake manifold, maybe an elbow piece?
Anyway, I have the pcv valve and it rattles when I shake it.
- and a very limited view of a grommet in the top of the valve cover that you
really can't even get a finger tip on.
- and a clear view of a 5/16th" hose nipple on the intake manifold.
I'm assuming that the pcv valve goes into the grommet on the valve cover
that is virtually impossible to see and harder to even touch
and then the 5/16th line goes to the intake.
I've heard a rumor that they use an elbow into the valve cover since it's so tight,
and MAYbe that's what he dropped.
Not sure what to do and certainly don't want to push the valve cover pcv grommet
into the valve cover and lose it inside the engine.
Family needs the truck and I'm just stuck in the middle on this one.
Maybe just plug the vac leak at the intake and hope nothing gets into the valve cover until it can be fixed correctly?
Thanks a million
  #2 (permalink)
Old 06-13-2012, 07:27 AM
Scndsin's Avatar
Scndsin Scndsin is offline
MS Sweet Magnolia Blues
Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.Scndsin has a spectacular reputation.
Yes there should be an elbow going into the grommet that routes the PCV valve parallel to the valve cover & out from under the upper manifold. There are many minor differences between years & models. I believe on my 150 it went toward the firewall before going up & forward to the top of the manifold.
I had a piece of formed hose left over from a hose kit & using the elbow, re-routed it forward & outside to make it easier to get to:
Click the image to open in full size.
__________________
David- Mississippi Chapter Leader
94 F-150 XLT 5.8/E4OD SuperCab, 2WD
Join the Mississippi Chapter, HERE
  #3 (permalink)
Old 06-13-2012, 03:54 PM
Thank you for confirming my suspicions.
I'll try it today.
...so the bottom line is that the pcv valve needs to be
connected to the valve cover with an elbow and then to the intake manifold vacuum fitting.
Simply amazing that it's in such an impossible place to even see.
but nice to know that's exactly what it is.
Search key had quite a few interesting stories but none very clear
about how to actually fix it since most were intact to start with.
It was mostly, 'reassemble in reverse order.'
Thanks
  #4 (permalink)
Old 06-13-2012, 09:54 PM
Scndsin's Avatar
If you've got the the valve, you can probably find an elbow in brass or pvc at your hardware store & fab up a line from the grommet to intake with some fuel line/vacuum hose. You might feel around behind the lower intake (there's a flat space there) where the orig may have fallen or it could be on the slope of the bell of the tranny. There are a lot of air injection vac lines back there too for it to hang on. If you haven't driven it, its gotta' be there.
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
