Changing out Pcv valve
Old Apr 17, 2009 | 09:07 PM
rough88's Avatar
rough88
Ok guys, Got a quesiton.
I have an 88 f150 with the 351w.
I cannot seem to find the pcv valve on this thing, Any ideas?
Also, my brother got the replacement for me and I am unsure if it is the right part. Its got two bigger barbs that hoses attach to on one end. Is that correct?
Old Apr 17, 2009 | 09:37 PM
fkaster01's Avatar
fkaster01
look behind the intake manifold on top of the engine, I've got a 95 f150 with a 351 and that's where i found mine, be careful taking the old one out, the stem broke on mine inside the vac line and I had to replace that too cause I couldn't get it out. Its really not in an obvious place. you should see a large vac line coming out of the intake manifold, follow that around and you should find it in line there, hope this helps
Old Apr 17, 2009 | 10:28 PM
HrdDrv's Avatar
HrdDrv
Last time I checked, PVC Valves are inserted in to the valve cover. Mine is on the passenger side.
Old Apr 18, 2009 | 04:35 AM
Blue Rebel's Avatar
Blue Rebel
Yup, pass side valve cover in the rear
Old Apr 18, 2009 | 05:42 AM
lew52's Avatar
lew52
On the 302 there in the valve cover . But on the 351 i think they are in the back of the intake ??? Lew
Old Apr 18, 2009 | 05:48 AM
Blue Rebel's Avatar
Blue Rebel
^^^^ your right... sorta. Its not actually in the valve cover on the 351, it mounts to the intake, and has a hose that goes to the valve cover. so... your looking for a hose that goes into the top rear of your pass side valve cover. It should be short, and at the other end you will find the pcv valve.
Old Apr 18, 2009 | 06:38 AM
fkaster01's Avatar
fkaster01
its definitely not in the valve cover... there is a hose and the valve ends up behind the intake manifold on mine... should be a stock location but its possible someone rigged it up to be back there
Old Apr 18, 2009 | 07:12 AM
EPNCSU2006's Avatar
EPNCSU2006
It sounds like he got an aftermarket PCV valve. An OEM PCV valve from the dealer would be a better part because it is designed for a specific application.
Old Apr 18, 2009 | 11:03 AM
Conanski's Avatar
Conanski
The stock setup for both motors has the PVC valve in the rear/top of the passenger valve cover and connecting to the intake manifold with a short piece of rubber tubing. It's easily accessable on the 5.0 but really hard to get at on the 5.8. The valve itself looks like this..
Old Apr 19, 2009 | 12:25 AM
rough88's Avatar
rough88
Alright, This answered some questions.
I now see the valve location,
I also discovered I have the wrong part.
Thanks for the helps guys, Off to get the right stuff!
Old Apr 19, 2009 | 08:50 AM
packnrat's Avatar
packnrat
Any trick to getting the fitting into the valve cover? just put together a 351W and did not install the fitting before the intake.
would hate to remove the upper just to push in this fitting.
Old Mar 1, 2010 | 04:58 PM
greg213187's Avatar
greg213187
I also am looking for the easiest way to change this item without removing the upper any advice??
Old Mar 1, 2010 | 06:50 PM
pete17c's Avatar
pete17c
Originally Posted by Conanski
>>> It's easily accessable on the 5.0 but really hard to get at on the 5.8. <<<
I can't imagine that you can't replace it w/o taking off the manifold (I've seen some questionable engineering from Ford, but nothing this ridiculous) .. it's mounted in a rubber grommet, get a hold of the f***er and pull to flex the rubber enough to give it up .. you may have to 'push hard' to get it back in too ..
Old Mar 1, 2010 | 09:46 PM
fkaster01's Avatar
fkaster01
It really wasn't that hard... hardest part was finding the darn thing. I broke mine trying to get it out of the hose so I had to replace the hose and the valve at that point. I've had no issue with that particular part of the truck since then but the 230xxx miles are really starting to take a toll and I may have to get rid of the big red ******* soon.
Old Mar 2, 2010 | 12:23 AM
'90-f150-302-5spd's Avatar
'90-f150-302-5spd
You dont have to take the intake off, its just in a tight place. I had to get up on the front of the truck and lay across the engine to get it.
