71 F250 CS swapped in a 78 F250 Tilt column....Wiring????
Hey all,
still working through the Project
So I put in a steering column from a 78 F250 for the Tilt feature. Problem is of course the wire connectors are no where near the same.
Anyone done this swap and or can someone point me in the right direction to figure out which wires go where??
I will see if I can find the color codes. Do a search. Thats where I got the color codes from. I put 1 in my 69 and started putting my Painless harness in. Going to finish it sunday. It comes with the connector for the 73-79 also so its just plug and play for me but I will try to get you the color codes tommorow before we go camping.
castone did you get both ends of the connector from the 79? Then you could make a plugin. Here are the colors. 79 tilt column. Outer 7 1. Yellow 2.White+Red 3.Green+Orange 4.Orange+Purple 5.Blue 6.Green 7.MT
1-4 inner. Blue+Red acroos from Yellow#1 Then Blue 3. White+Blue 4.Green+White across from MT.
Truck connector. 1.MT across from Yellow 2. White+Red 3.Yellow 4.Green 5.Blue 6.Red+Black 7. MT Inner 4 1.Green+White Across from Red+Black 2.White+Blue 3.Blue 4. MT I hope this helps. If not I cam PM. my cell# That way it will be easyer to explain.
Try this read! Great writeup on this exact swap. I'll be doing it on my '71 soon.
How to Install a Tilt Steering Column - FORDification.com
flip4eva83
01-15-2012 09:46 PM
projectbad78
09-04-2008 05:08 AM
jlasater
05-09-2005 10:23 PM
oldiron
05-08-2004 11:09 PM
