Which differential fluid?
Old Jun 17, 2012 | 04:25 PM
70-360fe's Avatar
70-360fe
What is a good differential fluid and how much do I need to fill it. 70 xlt ranger 360fe, thanks. Oh forgot driven daily and do some light towing.
Old Jun 17, 2012 | 04:50 PM
HIO Silver's Avatar
HIO Silver
Original gears? - 75w-90 dinosaur-based gear oil. If the rear axle has been rebuilt in the recent past - Royal Purple synthetic... you'll need 2 quarts. Valvoline offers 75w-90 with limited slip additive already incorporated.
Towing? Lucas Oil 75w-140 synthetic.
Old Jun 17, 2012 | 08:46 PM
70-360fe's Avatar
70-360fe
[quote=HIO Silver;11963028]Original gears? - 75w-90 dinosaur-based gear oil. If the rear axle has been rebuilt in the recent past - Royal Purple synthetic... you'll need 2 quarts. Valvoline offers 75w-90 with limited slip additive already incorporated.
Towing? Lucas Oil 75w-140 synthetic.[/quot
Not sure if i have a limited slip differential I like lucas products and not quite as expensive as royal purple. Would I have to get an additive if i used lucas, how much additive would I need..People at the parts store are absolutely no help. Would the valvoline work as good as the lucas oil, thanks.
Old Jun 17, 2012 | 09:24 PM
HIO Silver's Avatar
HIO Silver
Four ounces for a 9-inch.
If you're not sure if you have limited slip, get the Valvoline gear oil since it is already formulated with it.
Your call on Valvoline or Lucas. I use both.
Old Jun 17, 2012 | 09:51 PM
70-360fe's Avatar
70-360fe
[quote=HIO Silver;11964003]Four ounces for a 9-inch.
Your call on Valvoline or Lucas. I use both.[/qu
I have to return some spring compressors in the morning, finallly got front rear sway bars and new coil springs on. Guess I will pick up some valvoline while I'm there. Thanks!
Old Jun 18, 2012 | 04:49 AM
jowilker's Avatar
jowilker
Just to offer a different O, straight cheep 90 wt. gear oil has worked very well for 60 + years now. Some folk have extra jingle in their jeans for the pricey stuff, if you are one of them go for it.
For the masses it's no better. My O.
John
Old Jun 18, 2012 | 06:31 AM
70-360fe's Avatar
70-360fe
John
I was thinking sythenic you don't think it's better or llongevity is better? Thanks
Old Jun 18, 2012 | 05:00 PM
jowilker's Avatar
jowilker
All, I know there are no known issues running the old 90wt.
If you will sleep better at night knowing you spent more money on synthetic please do.
John
Old Jun 21, 2012 | 07:36 PM
70-360fe's Avatar
70-360fe
John
Well advance had the mobil LS synthetic in the wrong spot priced at 10.99 actual price was 18.99 so I just when with valvoline at 6.99. I would have liked to try the synthetic but at that price don't think it is that much better. Thanks for the help!
pepito113
2004 - 2008 F150
Feb 7, 2013 09:35 PM
jimbo285
1978 - 1996 Big Bronco
Feb 24, 2012 08:50 PM
smallblock351w
Oil & Lubrication
Jun 26, 2006 09:29 AM
Marc150
Aug 15, 2004 08:47 PM
joe phillip
Jan 6, 2000 08:50 AM
