Painting my truck..need help
I had this in the "paint" section but wasnt getting the response...(well the response I did get was well informative and I will accept their reply as if it was God himself) but I thought I would generate a more intuitive response here(meaning ...I am fixing to start asking more stupid questions..LOL.
OK...I started sanding my truck with 220....and it seems it goes straight to bare medal. Am I using to course of grit or is the paint just that thin?
Typically 36-80 is for stripping and rough body filler sculpting.
Then 220 is good for feather edging scratches and final body filler sanding.
400-600 is good for wet sanding after primer to smooth things out before paint
1000-2000 is for wet sanding the final paint in preparation for buffing.
You can take my words with a grain of salt, but I have worked in a body shop and have more than one 1st place show truck
Your paint must be VERY thin or you are not keeping the sander flat.
I used 180 in a good DA sander and it took the clear right off just perfect. I then went over with 320 to smooth things out and sme self etching primer to cover the metal until I get ready to prime the whole truck. When I get ready I will run over the whole thing again removing the self etching primer and shoot the whole truck with epoxy primer. For a really good finish you need to put a nice thick build on and stick sand it to get rid of imperfections.
