I've got a '93 IDIT that was stolen and in the process of being stripped when it was recovered. The main wiring harness under the hood was cut and now I need to replace it. Will any of the F-Series main harnesses work or does it need to be from an '93 Diesel?
I'm guessing the wiring harness is the same across those years if not very similar. Just stay within the same generation, and engine and you should be fine.
Thanks for the information guys. I lucked out and found a harness from a '93 diesel so I think I should be good to go there. I hope I'm as lucky with the rest of the parts I need...
