Scary bad noises
Old Jun 12, 2012 | 03:14 PM
Fordguy89's Avatar
Fordguy89
Scary bad noises
Ok so it's a little late to be asking this because I already just about have the heads off but the last time my 93 f250 with the 7.3 idi ran it made a thump. It was backfiring through the intake. From a distance it sounded like a two cylinder John Deere if you know what sounds like. So I ran it and cracked each injector line the noise just got a little bit quiter when I loosened the front one 0one the right side. So I took the valve covers off and saw parts of a lifter and a bent pushrod. This is caused by a stuck valve correct?
Old Jun 12, 2012 | 04:11 PM
turtlemann14's Avatar
turtlemann14
normally it is i figure you might as well take the head off.
or at least see if you can run a comp test
chasteen1156
Feb 15, 2019 07:18 AM
twtcad
13
Jul 28, 2011 08:47 AM
2ndmouse
Jan 30, 2005 12:16 PM
tskinner
Nov 9, 2004 10:22 PM
dieselcanuck
Oct 8, 2004 11:34 AM
