Modular V10 (6.8l)
SCT X3 & rev limiter adjustment
Old 06-06-2012, 09:47 PM
00250SD's Avatar
00250SD
00250SD is offline
Has anyone had any luck increasing their rev limit with an SCT X3? Several attempts to increase or remove mine have been unsuccessful. In 4 low 1st gear at WOT it bounces off the limiter at about 5,200, which is actually below the stock limit. Is there something in the stock computer that overrides the custom tune setting?
Old 06-07-2012, 08:09 AM
krewat's Avatar
krewat
krewat is offline
Site Administrator
I've never done it myself, I don't need/want to go above 5200 RPM. Matter of fact, I thought that the stock limit is 5200 actually.
The PCM has an input that reads the 4x4LOW signal. It's possible that it reduces the rev limit when your in 4LOW.
Maybe Mike will come along and speak to this.
Old 07-07-2012, 10:46 PM
00250SD's Avatar
00250SD
00250SD is offline
I guess no one else on here has pushed one of these beyond stock? I do sled pulling with mine and shifting probably isn't a good idea.
Old 07-09-2012, 03:48 PM
Aune163rd's Avatar
Aune163rd
Aune163rd is offline
well @ 5200 RPM your well past the peak torque of the engine anyway....
Old 07-09-2012, 05:48 PM
dkf's Avatar
dkf
dkf is offline
There are two rpm limiter adjustments in the tuner. One limits rpm in park/neutral the other limits rpm in drive. Bumping up the rpm limiter in park/neutral will not change anything when you are in drive.
FYI I would not go over 5300 rpm with the stock rods there is reason it was limited like that from the factory.
Old 07-10-2012, 01:08 PM
Ron_Manjenkins's Avatar
Ron_Manjenkins
Ron_Manjenkins is offline
Uh ya what everybody said. Mine at wot shifts at no greater than 5k. Kinda playing hot potato with a grenade on that one
Old 07-25-2012, 10:14 PM
00250SD's Avatar
00250SD
00250SD is offline
Sled pulling is mostly about momentum. I won't get far if I chug down the track at 3K RPM.
All limiters have been adjusted up. We've even tried shutting them off completely.
Has anyone on here actually broken a rod, or is that just more of the "I read it on the internet" so it must be true?
It seems there are few out there that have actually tried to push the NA performance of the 6.8 beyond very basic stuff.
Old 07-25-2012, 10:15 PM
00250SD's Avatar
00250SD
00250SD is offline
Sled pulling is mostly about momentum. I won't get very far if I chug down the track at 3K RPM.
Old 07-26-2012, 06:31 PM
kas83's Avatar
kas83
kas83 is offline
5,200 is stock limit, Mike @ 5Star has posted that before. With a 2 valve, I seriously doubt the thing could breathe at anything over that. What other mods does the truck have, and what gearing in the axles?
Old 07-26-2012, 09:44 PM
00250SD's Avatar
00250SD
00250SD is offline
CAI, Headers, dual exhaust w/X crossover, & the SCT with a custom tune. 3.73 gears & running 315/75/16 tires to drop the RPM's, which has not helped enough. It will spin to 6K or more, but only if eased into the throttle. At WOT it hits the limiter hard at 5,200. On a stock tune it would go to 5,400 but the power level is down.
Old 07-27-2012, 02:34 AM
kas83's Avatar
kas83
kas83 is offline
Try running 265s n let it hit 2nd gear. Or a tighter converter to get more wheel speed with the same rpm. I don't think sheer rpm from the engine is your answer here.
I would call SCT n see whats up with it if you can 'feather' 6k but matting it only nets 5,200.
redwood
1997 - 2003 F150
12-08-2009 10:24 PM
Benchwrench
03-17-2008 09:46 PM
crack
15
01-24-2007 01:05 AM
Quick Reply: SCT X3 & rev limiter adjustment
