1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Cruise control problem
Old 06-05-2012, 10:09 PM
49 Ford F-1's Avatar
49 Ford F-1
49 Ford F-1 is offline
The cruise control on my 99 sd is not working. It didn't have cruise on my truck before. I installed a new oem clock spring a used oem steering wheel on my truck. Any ideas on what could be wrong? there is no light that shows up when the on button is pressed.
Old 06-06-2012, 06:58 PM
AllaboutMPG's Avatar
AllaboutMPG
AllaboutMPG is offline
Originally Posted by 49 Ford F-1
It didn't have cruise on my truck before. I installed a new oem clock spring a used oem steering wheel on my truck. .
Do you mean you are trying to add cruise to a truck that didn't have it or did have it and it quit working??
One leg of your brake switch has do do with cruise. My 2000 had a problem were my brake lights worked but the cruise didn't. Took the switch apart and cleaned it. Cruise came back.
Old 06-06-2012, 08:33 PM
49 Ford F-1
adding cruise it never had it before.
Old 06-06-2012, 09:03 PM
BigAlsPSD's Avatar
BigAlsPSD
BigAlsPSD is offline
I assume this is on the 7.3 in the sig? For some reason I didn't think the 99's had the bulb in the dash to light the cruise control light IIRC. Also with a 6 speed, you need to make sure the Clutch Pedal Position Sensor is working correctly.
Old 06-07-2012, 02:18 PM
49 Ford F-1
Yes the 7.3 in the sig. Ok ill check the clutch pedal sensor
Old 06-07-2012, 04:09 PM
49 Ford F-1
I checked the clutch sensor and it was broke up so I'm getting another one tomorrow hope this fixes my cruise. Will post if it fixes the cruise our not.
Old 06-07-2012, 09:06 PM
dchamberlain's Avatar
dchamberlain
dchamberlain is offline
The cruise control on a 7.3 DI is entirely a function of the PCM. If it didn't come with cruise, it's possible the PCM is not programmed for cruise functions. It's also very unlikely anyone is going to be able to re-program it.
Old 06-07-2012, 10:03 PM
49 Ford F-1
On a 99 the pcm doesn't have to be reprogrammed. I have found that out
FL7.3Diesel
06-04-2018 11:10 AM
firebug
10-29-2010 06:39 AM
Big Sky
07-22-2007 10:04 PM
Mark76f250
09-14-2004 03:33 PM
bronco cam
1978 - 1996 Big Bronco
17
11-21-2002 09:33 AM
Quick Reply: Cruise control problem
