Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Fuel System Guides
- How to Replace Fuel Filter
Step by step instructions for do-it-yourself repairs
Trick to Removing Fuel Filter
I've been using the 'special' plastic ring tool to try and separate the lines from the filter, but with no joy. I can feel the tool compress the spring(?) on both fittings, but no matter how hard I am able to pull the lines won't come off.
Any suggestions?
Thanks in advance.
Any suggestions?
Thanks in advance.
Thanks for the all the advice.
I did spin the filter in order to ensure it wasn't frozen. Then pushing the fuel line towards the filter while pressing the tool into the coupling seemed to work. I don't remember, but I'm sure there was twisting and colorful words required to free it up. I was a bit surprised exactly how much fuel was in the filter though.
Didn't have much issue pulling the lines off. I used the small plastic round tools. Worked at first try.
Forgot to get back to this post. Glad the OP got it figured out.
When I change the filter on my Lightning, I pull the fuse for the fuel pumps and then crank the engine. It usually starts then sputters dead. There will always be fuel that pours out, but at least it's not spurting under pressure.
Stewart
I did this a couple weeks ago on mine. Same year/engine. I first pulled the cutoff switch connector and started it up to release some pressure. I still got a nice gas-shower from all the fuel coming out. safety glasses are a must.
Stewart
bigblackmachine
1997-2006 Expedition & Navigator
10-08-2011 01:14 PM
wraysp
06-12-2010 05:30 PM
