Internal or external Balance?
im assuming that your in the 7.5 -460 forum that thats what you have... the 351 bellhousing will fit..he motor plate (the one betwwen the motor and flywheel) will fit but needs to be trimmed around the crank... the flywheel and clutch i use is from a 75/76 390 (diagphram stlye)as there nuetral balance. be sure to get a roller crank pilot shaft bearing for a 460 though.. the bearing for the 390 fits but in the wrong place...learned that the hard way it cost me a bellhousing..the 351 starter should work solong as your not running a monster compresion big block..
Once I got the engine at the right angle everything slid right in. We started by sliding the trans back but could never get it to seat. Finally we said screw it and pulled the front clip and motor. Only takes like twenty minutes if you have done it before. By tilting the front of the motor up it made everything slide together.
Suzukiboy2012
04-25-2012 02:24 PM
rathighboy
10-19-2008 07:29 PM
rk40977
32
10-19-2003 10:13 PM
fastford456
02-08-2003 10:15 AM
