What is this "banjo-bolt" upgrade?
I have an '05' and I have read in a couple of threads about this upgrade from the 6.4's but I can't seem to find reference or pics or part numbers as to "exactly" what it is? How long does it take to put these things in and can a regular semi-mechanical guy put them in?
the 6.0 banjo bolt has some restrictors in it, the 6.4 banjos do not. These fit on the fuel line at the heads and thus open more flow to the injectors. I do not know how hard they are to install as I had mine done when I had the work done to R&R the oil cooler. Supposedly they can be done by the home mech. Also if you do these include the upgrade to the fuel pressure spring/regulator. My truck seems to run much better with good fuel flow with the banjo's. There are part numbers and a lot of discussion in the archives. do a search.
Tousley - 6.4L Banjo Bolts
They're bored out a bit and there's no check valve in the bolt. But it's probably a waste of $10 if you have the updated blue pressure spring installed and your fuel pressure is over 45psi at all times.
Look at the pressure regulator on the secondary filter housing. Follow the two fuel lines to the front of each cylinder head. Remove the bolt that goes through the fuel line and into the head and replace. You need two, the $10 kit I linked to above. I don't know what the clearances are like, but the torque spec is 28 ft-lbs so a gear wrench should work. But again, not really going to do much.
Changed mine during blue spring upgrade. Don't know if it's the blue spring thing or the banjo bolts but it runs like a scalded cat. Banjo bolts can be seen on the front of each head. Drivers side is a pain to change plus you have to install new washers. 2 each if I remember correctly. Tousley's have the bolts and washers. Problem with driver's side is upper radiator hose is in the way. PM me and I'll send you a pic of the removed bolts showing the internal check valves.
My 06 DRW will break loose a four tires on payment since this mod. Don't normally do this but my buddies are impressed. All stock except for that and lost the kitty.
I've been running the SRL tune for awhile and my truck is fiesty. I did the blue spring finally 1 month ago and the truck is downright mean now. Much better throttle response and butt dyno says it's pulling harder at higher RPM. I got a $250 ticket last month while "testing" out the new spring. I was burning 35" rubber for over 1 block when I finally noticed the LEO
I've already spent the $16 for the 6.4 banjo bolts...just need to put them in the motor
I just took the check valve out of my stock banjo bolts when I had my head off during HG change. I don't know if it made a difference or not. But it's only a small snap ring that holds the check valve in there. Pop the snap ring out, tap bolt on table an all the insides fall out. Restriction got. Free flowing now.
