kool blue lightbulbs
Hey,
do any of you have this problem?:
I changed my regular white light bulbs in my head lights to aftermarket "kool blue" light bulbs.
Well i plugged them in and turned them on ... the passager side is birght like they are suppose to be, but the drivers side light bulb is really dim.
Could it be the bulb, the plug, or wiring? Why would it be dimmer?
Any suggestions?
Thanks KMAN
Any suggestions?
Thanks KMAN
I have used the Sylvania Cool Blue's for about 6 months and they are great. For $18.00 at WalMart, I now have much brighter than stock lighting and no problems with them whatsoever. You could go ahead and pay $25.00 each for Silverstars but I don't see that they are that much of a difference.
If you haven't found the problem yet, check the high and low beam(single light each side). If both are very dim look for a bad ground. Likely a broken wire on the socket. A bad ground forces the juice thru both Elements causing a High Resistace condition and on other FORDS I have had, it found a ground thru the hi-beam indicator on the dash. Weird
