Pulled a heavy load now trannys dripping??
I have a 91 f150 with a 300 6 and an e4od tranny. Our 4610 ford tractor broke down in the field so i pulled it maybe 50 yds with my truck which wasnt easy but it did it.
Now my tranny is dripping at a decent pace it looks like from the hole in the bottom of the transmission, i drove about ten miles home and it still shifts fine
what could i have done??
I did the ZF swap in my 96 F150 as part of a 4wd conversion, totally worth it. They're geared perfect for the way a 300 six makes its power. Also a far cry in every way from the M5OD it replaced. Anyhoo yes I would say you most likely overheated the trans as mentioned above. Keep an eye on it, see what happens... that's my best advice it this point.
Judging from your pic in your signature, that truck has worked pretty hard times before, it's probably not the first time it gets to hot, but that tractor did it in, and that seal must of gotten so hot, it harden, cracked and leaks now.
Since you have a shortbox F150, does it even have an Aux. tranny cooler?
My buddy did the same thing pulling round bales up a hill with his F250 with a 7.3. The hill is very steep and its probably a 1/2 mile distance from top to bottom. It only took 3 bales for both the front seal and the seal for the bottom pan to leak as fast as you could put fluid in. E4ODs aren't very good trannys for hard work. I don't know why Ford even bothered using them in anything.
ravens fan
05-24-2012 10:00 PM
jdr37
07-08-2010 06:35 AM
F350_Hauler
07-03-2007 09:37 PM
MDB
06-10-2007 08:22 PM
