Carb Overhaul 239
Carb Overhaul 239
Hi, everyone.
I got Lizzy to run breifly. So smooth when it did run.
Well I am working on the carb and I tore it down and their is a lot of wear on the pump discharge needle 78-9594.
Does this part come with the rebuild kit?
I have not been able to tell if it does. I have a kit coming from Mac's.
Does anyone know what it does? Is their any place to get this if it is not in the kit?
Can it just be run as is or can you some how repair it?
THanks for the help
Neal
THanks for the help
Neal
It doesn't have to be an airtight seal, it just prevents the piston from sucking gas back down from the nozzles when you let up on the gas.
Up above, I meant if you have an old brass float needle, you could use that as a replacement. If your accelerator pump needle has a groove in it, it sounds like someone already made the substitution. Vintage Speed sells the real deal separately: http://www.parts123.com/parts123/yb....Z5Z5Z50000106a
LDH
06-28-2003 06:15 PM
canadianfordman
07-29-2002 02:47 AM
