Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 05-22-2012, 10:29 AM
Y-oh-Y's Avatar
Y-oh-Y Y-oh-Y is offline
Garage is empty, add now
Y-oh-Y is starting off with a positive reputation.
Self-adjusters
I am looking to install self-adjusting brakes on my 60 f100, has anyone done this ? What years would fit ?, early 60's ? I have stock drums front and back. Thanks, Mark
  #2 (permalink)
Old 05-22-2012, 05:26 PM
blue57's Avatar
blue57 blue57 is offline
1957 Ford F-100
blue57 is starting off with a positive reputation.
Check this out
Go to this URL for your answer.
http://www.ford-trucks.com/forums/63...um-brakes.html
Good luck.
__________________
Driver / Beater / Tow truck - 57 F100, 300 six, 4bbl and EFI headers, AOD, 3.70 gears.
Eternal Project - 36 Ford Ratrod PU - 300 six w/AOD
Civisaki trike - 1500cc Civic powered Kawasaki trike project
So many projects - so little money
  #3 (permalink)
Old 05-22-2012, 06:01 PM
Y-oh-Y's Avatar
Thanks, I have been looking at why it wouldn't work for a couple of weeks now, ain't found a reason yet. Mark
Good luck.
  #4 (permalink)
Old 05-22-2012, 07:33 PM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
I did it by installing a later model rear axle. They are easy to come by and cheap. Lots of advantages.... gearing etc. Last night I replaced the wheel cylinders on my '92 axle in my '59. They were in stock at napa for $15.65 each, and that's for a one ton. Actually last night was the first time I ever dealt with a brake job with self adjusting brakes. Sort of clever how they work, but lots of fussy little parts....Still better than crawling under the truck and trying to remember which way to turn the spoon ......
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #5 (permalink)
Old 05-24-2012, 01:45 PM
blue57's Avatar
1957 Ford F-100
Yeeeaaahhh buddy.
__________________
  #6 (permalink)
Old 05-28-2012, 06:39 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Self adjusters were not available for F100's until 1964. These self adjusters only work (if they work at all!) when you back up and step on the brake pedal.
The adjuster cable (there are 4, one inside each drum) is notorious for snapping. This may allow the cable guide to float around inside the drum.
What happens when this little charmer gets between the shoe and drum and you then step on the brake pedal?
The cable guide chews the hell oughtta both the shoe and drum. And, the adjustment wheels rust up, rendering the whole set up inoperable. NAPA once sold a kit to remove the pesky self adjusters.
Forgetaboutit! IMO, they're more trouble than they're worth.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
Tags
1966, adjusters, bronco, ford, install
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
