Which year 9" direct bolt in for 1952 F1?
Hey There Guys and Gals. I usually hang out in the Bump section but I need some info. I tried the search engine above in between phone calls here at work but no luck. My girlfriend's son has a 1952 F1. Looking for a 9" to stick under it. Years ago I heard there was a few years of factory 9" that would bolt directly under a 1955 F100 I had and I am assuming same for a 1952 F1. I want to say 1966 to 1968 F100 9". Am I correct? If not, which year span?
Here it is:
<TABLE id=post9594201 class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR><TD class=thead> #9 (permalink) ******** type=text/javascript> vbrep_register("9594201")*********>
<!-- status icon and date --> 11-23-2010, 01:41 PM <!-- / status icon and date -->
</TD></TR><TR><TD style="PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=alt2><!-- user info --><TABLE border=0 cellSpacing=6 cellPadding=0 width="100%"><TBODY><TR><TD class=alt2></TD><TD noWrap>old_dan ******** type=text/javascript> vbmenu_register("postmenu_9594201", true); *********>
1952 Ford F-100
</TD><TD width="100%"> </TD><TD vAlign=top noWrap>Join Date: Aug 2010
</TD></TR></TBODY></TABLE><!-- / user info --></TD></TR><TR><TD id=td_post_9594201 class=alt1 sizcache="2" sizset="93"><!-- message, attachments, sig --><!-- message -->The data in the article will be very helpful.
I just finished getting a Ford 9" for my F1 restoration project. The data in the article is correct....if you can find a 57 to 72 F100 donor vehicle, the axle will bolt directly to the F1 springs.
In retrospect I would have saved some money by buying an 8.8 inch axle from an Explorer. I would have been able to buy a complete axle in good shape with disc brakes attached for around $400. Add $60 for some new spring perches (you'd have to move the spring perches on the Explorer axle)
The 9" was more....$225 to buy it, then I went through it and replaced all of the bearings (including the axle bearings) (that was $300). I also had to replace the brakes (shoes, wheel cylinders, drums, self adjusters and parking brake cables) ($200 more). My labor doesn't count!
The plus is that I know that the axle will outlast the rest of the truck.
Dan
1952 Ford F-100
Dan
revamp1953f100
01-15-2018 05:37 PM
ccbb
16
12-25-2010 07:55 PM
