Which computer for maf swap
Old 10-03-2012, 12:51 PM
UNTAMND's Avatar
UNTAMND
UNTAMND is offline
Personally, I'd put a stock maf on and 19lb injectors, adjust regulator to 39-40psi no vacuum and see how it runs.
Then once you get it running well with stock equip, then put in 42lb injectors, 90mm maf, and let Dyno guy tweak fuel pressure.
(Just as a little info, most factory maf are for 19lb injectors, ford adjusts ecu program to accommodate injector size)
  #62
Old 10-03-2012, 12:57 PM
bearster18's Avatar
bearster18
bearster18 is offline
This is actually what I'm going to plan on doing. Just gotta find a stock maf now for cheap!
Kappa505
16
01-18-2013 05:25 PM
TheRoadVirus
15
04-05-2008 06:40 AM
chloichina
Computer Chips & Tuners
11-13-2007 12:45 PM
*92flareside*
09-28-2005 10:13 AM
Ford427Strokr
32
03-31-2004 04:01 AM
Quick Reply: Which computer for maf swap
