First Tow
Bought a Crusader 298 bunkhouse made by Primetime. Dry weight 8400, hitch 1380, told wife we got to weigh everything that goes in it! Should be delivered Friday and we leave Tuesday headed for Missouri Ozarks, can't wait! Will post pics ASAP. Spoke with dealer today, said on open road fairly flat terrain use all 6 gears in T/H, when in more hilly terrain if trans begins to hunt then lock out 6th gear and so on just to keep trans from shifting back and forth so frequently. Really appreciate all the input on FTE, thanks guys!
the following video was my 2010 5.4 3.55 4x2 towing a 3800lbs message board in a section of rolling hils. granted, your EB has more power and more gear, but you will be towing more load with more aero load as well, so i would expect your truck would behave similarly in similar terrain.
Kind of a boring video, but if you decide to give up 3 minutes of your life, you can count the shifts. on the average, it would only hold a gear for about 15 seconds before it would upshift or downshift. I will qualify this with the fact that i tow with the cruise set at 65. instead of a long dissertation on why, i'll just say "i just do" ... i know some dont, that's the only reason i mention it.
2010's do not have the ability to lock out gears, so count your blessings that you will be able to. you can modulate the shifting *some* if you drive by foot, but as soon as you lift it will upshift unless you lock 'em out.
sorry if this bores you.... but ... eeeh
I have to use cruise-control on long trips to keep my right foot and ankle from painfully swelling up like a balloon. I've had it swell so badly, I was afraid the skin would split.
Evening guys, preparing for my first fifth wheel tow with the HD 150. Obviously will be using tow/haul mode, question is, do any of you lock out 6th gear using select shift and just tow in the 5 available gears? I realize this may be my old school thinking to protect the overdrive but coming from a '95 150 makes me wish I'd done it more often! Also, any value in using higher octane fuel, 89 or higher while towing? Thanks for your input!
Good point about the cost.
AND your are correct per the Ford Owners manual about the Eco-Boost.
Quoted:
Quoted:
Octane recommendations
3.7L V6/5.0L V8/6.2L V8 engines
Your vehicle will run normally on 87 octane regular fuel. Premium fuel
will provide improved performance.
3.5L V6 EcoBoost™ engine
Your vehicle is designed to run on regular fuel with an octane rating of
87 or higher. For best overall performance, premium fuel with an octane
rating of 91 or higher is recommended. The performance gained by using
premium fuel will be most noticeable in hot weather or in severe duty
applications such as towing a trailer.87 or higher. For best overall performance, premium fuel with an octane
Rich K
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
06-15-2009 11:26 PM
jmo1979
10-26-2006 09:36 AM
