Rear end chatter...
Rear end chatter...
Long story...
Short version...
Does this sound like the factory limited slip going out?
When ever my wife turns, or accels hard you get a bad shutter, its been getting worse over the last few months.
Took the rear end apart and everything looks fine, but while its up on jack stands its extreamly hard to turn the wheels and will chatter like it does when your driving (altho much slower). Its the only thing I can come up with that would cause this issue.
When I changed the fluid about 3 years ago, I did not add the friction modifier. Forgot, or what ever... Could this cause the clutches to wear out quicker to where the steels are just locking up?
Damn thing feels like it has a locker in it around corners.
Short version...
Sounds like limited slip to me.
My factory one sucked really bad, so when I changed the fluid I didn't add the modifier to make it more aggressive. Now it chatters sometimes on turns and such.
I've been looking into taking it down to Six States and getting a new locker put in, but I've done enough to stimulate the economy this year with truck mods.....
Sometimes, it takes 2 bottles of additive, and you're supposed to do several 'donuts' in each direction (after adding it) to get the additive where it belongs - inside the clutch packs.
I like my tight limited slip (I added only 1 bottle and it chatters a bit), as it helps me get up my driveway in 2WD without locking the hubs.
Sometimes it can take a few hundred miles for the friction modifier to fully get in and work. I had a Navigator that I had to road test over 400 miles for it to go away. I bet the customer the $140 in fuel I would use that it would. It did. and it was bad.
There is only one type of friction modifier that is the best. No other FM works like the old Ford Racing friction modifier does. It is now sold by Dana Spicer.
Use 2 bottles.
Differential Friction Modifier Additive - Dana Spicer - 43161
This is the only kind I have used for the past 20 years. with success.
Don't waste your money on anything else.
Warning....it stinks....bigtime!!!
Use 2 bottles.
wildstang
1999 to 2016 Super Duty
04-27-2010 12:22 PM
