1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
F350 Fuel Tank Thoughts
Old 05-18-2012, 11:40 AM
Westyswoods's Avatar
Westyswoods
Westyswoods is offline
Just finished extending F350 137 WB to 161WB. I do not like the way stock fuel tank will mount back into place. I am contemplating using space between frame rails and first cross brace for storage under custom made dump box.
Any thoughts on saddle fuel tanks outside frame rail or fabbing tank to sit crosswise between frame right behind cab. I understand need to keep clearance above drive shaft and exhaust..
Thanks for the feed back in advance.
Westy
Old 05-18-2012, 02:06 PM
redford's Avatar
redford
redford is offline
Received 1,565 Likes on 913 Posts
IIRC, the Excursion fuel tank sits between the frame rails, behind the rear axle.
Old 05-19-2012, 12:21 PM
cay5628's Avatar
cay5628
cay5628 is offline
and the Excursion tank is 44 gallons.
Old 05-19-2012, 03:35 PM
Westyswoods
Thanks
A couple questions on the Excurion tank. Can anyone give me the specs/dimensions of the tank? Where can I find them? Are the connections the same as F350 SD?
Sounds like a great option and special thanks to both respondents?
Any other ideas and thoughts out there.
Westy
Caneco
2017+ Super Duty
06-03-2019 03:28 PM
Leebus
04-18-2019 03:09 PM
batt312
11-20-2008 04:01 PM
rankhankyellow
03-06-2004 10:10 PM
greghoffmann
13
08-02-2001 12:26 PM
Quick Reply: F350 Fuel Tank Thoughts
