1975 Ford F250 Highboy
Old 05-15-2012, 11:58 AM
BigRig232's Avatar
BigRig232
BigRig232 is offline
My grandpa just recently gave me the keys to his old 1975 F250 Highboy and said "If you can get it cranking, you can have it." And I got it cranked and running after it sat in the yard for 4+ years. Now I have a few questions about this truck if anyone is willing to help. I am going to replace all the wiring, clean the fuel line, and clean out the tanks. Other than that is there anything else that people might think needs to be done with it?
Old 05-15-2012, 12:02 PM
77f-250's Avatar
77f-250
77f-250 is offline
change the in line fuel filter that screws into your carb and change the fluids just sitting there they go bad and just look at it and see what it needs. Other than that it ought to be fine Good Luck with her. and welcome to FTE
Old 05-15-2012, 12:34 PM
montana_highboy's Avatar
montana_highboy
montana_highboy is offline
Change out ALL fluids, filters, etc., do a basic tune-up and don't forget to inspect the brakes! it doesn't take much to resurrect these old beasts.
Old 05-15-2012, 12:50 PM
ChiefM's Avatar
ChiefM
ChiefM is offline
Welcome to the forum !!!!
They pretty much have you on the right track, 4 plus years I would do a quick inspection on everything and change all the fluids. These are really easy trucks to work on. Feel free to ask any questions, we have a lot of friendly and knowledgeable people on here.
Good luck and post pics of your progress, we like pictures.
Old 05-15-2012, 12:56 PM
82GT's Avatar
82GT
82GT is offline
Take a good look at the tires too, dry rotted tires can be dangerous
Old 05-15-2012, 04:01 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,290 Likes on 2,446 Posts
After you change all the main fluids and start driving it, watch for new leaks out of old dried up seals. Front/rear main, trans, brake cylinders.....front axle seal. Let it warm up and get some elasticity back into the valve's so it does not start smoking.
Might not hurt to change the valve cover gaskets, and the trans fluid/filter and pan gasket. Drop and drain and clean out all the gas tank/air blow out the lines with paint thinner to break up any varnished fuel.
Fuel filters and add a few inline to catch any stuff that loosens up later on and it does not go to the carb. Do not over torque the pan bolts, great place to get a leak.....
Why replace all the wiring, mice ate it? Watch out for wires to ground out and burn up something under the dash.
Old 05-15-2012, 11:07 PM
Blue Goose's Avatar
Blue Goose
Blue Goose is offline
Check your radiator too. Make sure its not too restricting from corrosion. My old 75's radiator was bad after sitting for a long time. Basically when you change coolant look down into your radiator.
Old 05-16-2012, 11:21 PM
dakotarider's Avatar
dakotarider
dakotarider is offline
Check her out
Big rig, congrats on the great score! I am going thru the same thing but my truck has sat a lot longer. Fluids, gas tank, brake lines, tires, batter, starter and the such. Mine only has 77k on it but sat for about 15 years. Have fun with it!
Old 04-25-2013, 06:52 PM
Ted's 75 Ranger's Avatar
Ted's 75 Ranger
Ted's 75 Ranger is offline
Have owners manual
I have a 1975 Ford F250 Ranger 4x4 . I have the F-100 thru F-350,P&M series operator's manual! If it will help?
Old 04-25-2013, 07:29 PM
410 Highboy's Avatar
410 Highboy
410 Highboy is offline
Went through this with my '75 Highboy . One note your fuel filter might be on the fuel pump like mine was .
Good Luck .
Great truck and simple to work on .
Machduty
2017+ Super Duty
05-13-2018 12:05 PM
ranger*al
63
10-20-2009 08:30 AM
BigRed1967
07-09-2009 04:14 PM
WA-SuperPickle
17
01-07-2009 10:31 PM
Martyf100
19
11-21-2006 10:05 AM
Quick Reply: 1975 Ford F250 Highboy
