04 expl with REAR DVD Please help
So I installed a new aftermarket head unit and can not get the rear DVD to stay powered on. Goes on, shows the ford logo and shuts off…
I have these 2 connectors (below) from the factory unit and was wondering if.. 1) does the Corp Protocol A and B need to be connected to something and 2) does the rear DVD take a different voltage ie.5 volts and not 12 (side note how is the DVD grounded, is it from the stock head unit?
20 pin
03-04 C240a (BK) with DVD player
1 - not used
2 - not used
3 - not used
4 - not used
5 LG/BK Audio System On (ASYSON)
6 LB/PK Audio Corp Protocol A
7 TN Audio Corp Protocol B
8 - not used
9 GY/BK vehicle speed signal +
10 - not used
11 - not used
12 - not used
13 - not used
14 YE Audio/climate Control Switch Radio Signal
15 - not used
16 - not used
17 OG DVD Player to Audio Unit Right +
18 YE DVD Player to Audio Unit Right -
19 RD DVD Player to Audio Unit Left +
20 WH DVD Player to Audio Unit Left –
16 - Pin
<hr noshade="noshade" color="#d1d1e1" size="1" width="100%" align="center">
03-04 C240b (BK) with DVD player
1 RD/BK Illum Input
2 BK Illum Ground
3 GY/YE Volt at start
4 not used
5 OG/RD RR +
6 BN/PK RR -
7 WH/LG RF +
8 DG/OG RF -
9 WH/YE Volt at all times
10 BK/PK Accessor Delay Relay Switched Power
11 BK/OG Ground
11 BK/LB Ground
12 GY/LB LR +
13 TN/YE LR -
14 OG/LG LF+
15 LB/WH LF -
16 BK/LB Ground
20 pin
1 - not used
2 - not used
3 - not used
4 - not used
8 - not used
10 - not used
11 - not used
12 - not used
13 - not used
15 - not used
16 - not used
16 - Pin
1 RD/BK Illum Input
2 BK Illum Ground
4 not used
5 OG/RD RR +
6 BN/PK RR -
7 WH/LG RF +
8 DG/OG RF -
11 BK/OG Ground
11 BK/LB Ground
12 GY/LB LR +
13 TN/YE LR -
14 OG/LG LF+
15 LB/WH LF -
16 BK/LB Ground
Chance_Thomas
05-17-2017 01:31 AM
IAFordFan
12-11-2006 12:43 PM
tulane
1997-2006 Expedition & Navigator
07-16-2003 03:20 PM
