changing front rotors what brand to get?
well i got my truck 3 years ago changed brakes asap when bought it bought carquest or napa rotors and pads since then they have warped badly so i cant decide which ones to get leaning toward powerslot but oem also look good to me what you all running for replacement rotors. rotors and pads still looking good just cant take the shaking when stopping.
Not Napa... mine are warping after 25K and I don't use them wrong, I know how to drive.
I think I'm gonna get a set of the slotted one's Riffraff Diesel sells as well as the "green" pads.
I've run the cryo slotted rotors and hawk pads for around 100k now. No complaints. Stops better than stock. We put EBC yellow stuff on the wife's truck on standard rotors and it stops as well as my truck (but hers has a 4" lift). We put EBC yellow stuff on the Excursion with whatever rotors came with the last brake job and autozoo rear rotors and it stops better then either of our trucks.
I've never had an issue with warped rotors, but I try to keep an eye on my slide pins and make sure all 4 brakes are working properly. If you let 2 or 3 calipers start to stick, you're asking for trouble.
Where did you get these? Was it a complete "set"/"kit" or did you piece everything together( rotors, pads, hardware)? I am very interested since mine is almost due.
I got the EBC sport rotors and yellow stuff pads last week for the front. They look and work great. One thing is if you don't like noise these are not for you. The drilled and slotted rotors make a funny noise while spining. Has nothing to do with the pads I believe, I think its the slots making noise. Its not real loud butt if you are **** like some of us are about noises in your truck they may not be for you. The instructions even tell you if you don't like noise don't use them! They do look and work great if you don't mind the noise.
Crewcab Turbo - Noise? I have never heard anyting from the brakes. These things are biased and have to be installed on the correct side or you could get a "thup" on the grooves. If you look at the photo of the driver-side rear in my previous post, do yours match this?
The rotors may look OK from the outside, but I'd shine a light on the back side of the rotors and inspect them. The slide pins on the calipers are a common failure point, so the calipers just push outward on the rotors and create heat, noise, vibration, and premature wear. OEM rotors are great, they were designed for this beast. I ramped mine up (link in my signature) because I tow in the mountains, but it was expensive. Time and miles will let me know if I tossed too much salad.
