Where to install 0-100psi oil pressure gauge?
I have this gauge, and a few others, and I was going to try install them this weekend.
Riffraff Diesel: Oil Pressure 0-100 PSI
It's the ISSPRO EV2 R17211 0-100psi oil pressure gauge.
Any ideas where to put the sensor? I have read about putting it into the oil pressure test port but it looks like a real bear to get to.
Anyone know if it'll really be that bad to get to?
Should I use something like the Strictly Diesel Fuel Pressure Adapter that I have for my fuel pressure sensor? - will the threads be correct??
Thanks!
Thanks!
The LPO is one place but some do get a Diffrent Oil Filter Cap and come off the CAP
I also think the LPO Test port would be the MOST ACCURITE Since thats where it ended up during the Design/Blueprint of the 6.0L
Here is a Link I saved
LPO gauge setup
https://www.ford-trucks.com/forums/1...test-port.html
Coming off the Oil Filter Cap Might be OK too since the LPO Regulator comes Before it
LPO gauge setup
Thanks Benny,
I have read that thread and sent the author some reps.
Does anyone know the threads that go into the fuel pressure port?
If it matches the oil pressure port then I think I'll go with another of the Strictly Diesel lines. I think I'll try tomorrow and see how this one goes and report back.
Can't rep you at the moment, here's an IOU
I just bought a replacement oil pressure sender.
It is note the same size/threads as the fuel pressure test port,
I am comparing it to the plug i removed to install my
FP sender.
i was thinking of using another STrictly Diesel fuel pressure
adapter as well, but it doesn't appear it will fit.
FP sender.
