Aftermarket AC ??'s
Old 04-23-2012, 11:49 AM
hairyboxnoogle's Avatar
hairyboxnoogle
hairyboxnoogle is offline
Aftermarket AC ??'s
Well since i went through all the work to cut a hole for the factory AC box. It looks like its not going to stay. Is anyone familiar with a few of the different varietys of the AC aftermarket? I would like to keep my factory dash controls, as well as maintain use of my dash vents.
I need the giant thing moved to make way for a turbo that rivals its size, and sadly, that is the only spot i can think of to put it.
Only other thing i can think of is going to a later model pickup and using the air box from it as they seem quite a bit smaller that may allow for the room i need, but im not 100% sure. My FF tower is coming out to so that will help. Just looking from some ideas on an AC unit that goes under the dash instead of though it, and some ideas how to use the stock controls.
Thanks guys,
Mike
Old 04-23-2012, 12:22 PM
ChaseTruck754's Avatar
ChaseTruck754
ChaseTruck754 is offline
have you thought about the "dealer" air or similar, vs. the factory air?
Here's the threads I have saved from here on AC stuff. Might be something in there you can use.
https://www.ford-trucks.com/forums/8...lled-ac-4.html
https://www.ford-trucks.com/forums/8...-system-2.html
Aftermarket AC - Ford Truck Enthusiasts Forums – good info!
https://www.ford-trucks.com/forums/9...-c-kits-2.html - lots of links & info
and here's a couple cool aftermarket AC units
Under Dash AC Unit - Speedway Motors, America's Oldest Speed Shop
Slim Line Heat/Air Unit - Speedway Motors, America's Oldest Speed Shop
Old 05-02-2012, 10:01 PM
hairyboxnoogle
Thanks man ill take a look at those, as long as its more or less mechanical, i should be able to cobble it together to work with my factory air instuments. Dealer air would kinda work, but im not sure how easy it would be to keep the dash vents. The under dash air box replaces my factory floor/dash/defrost box. If i can find another i might see if i can connect the important part on top of the dealer air box. None of that probably made any sense, but still i appreciate the links.
Old 05-02-2012, 10:23 PM
SuperDuty93's Avatar
SuperDuty93
SuperDuty93 is offline
This is what i will be going with. They even give me factory style vents
Aftermarket Air Conditioning For Automobiles and AC parts
Old 05-02-2012, 10:44 PM
hairyboxnoogle
bah dbl post
Old 05-02-2012, 11:15 PM
crsweet78's Avatar
crsweet78
crsweet78 is offline
Im using Vntage Air. I got rid of my old heater and a/c assembly and put this unit in thats half the size. All servo controlled, no cables, comes with relays and circuit breaker. You can choose whatever control panel you want and probably reuse your old vents.
Old 05-02-2012, 11:25 PM
hairyboxnoogle
I like that idea. I suppose that leaves the factory foot heat un-altered? Worst case scenario, i can run the AC to dash vents only, and heat can be defrost/floor like the base models. If its all electric controlled... i should be able to come up with a way to make everything work off of my factory AC switch / blower switch, maybe.. some diods a few headaches and some solder ought to make it happen. Have it all setup so that when the dash is set to AC, it only powers the the AC unit instead of the AC and heat blower.
Or the pics finally loaded... does that air box have both heat and AC in it?
Old 05-02-2012, 11:48 PM
crsweet78's Avatar
crsweet78
If you do something like mine, all your old stuff gets torn out. You install the new unit that is everything combined.The controls you buy for it allow you to run a/c or heat out the floor, vents, or defrost. Dont try to piggy back it onto the old stuff or use the old cable controls, youll end up just making it too difficult. Heres all their controls they sell.
http://www.vintageair.com/catalog11/pg46wc.pdf
Any of them will work with the gen II kit. The base model controls should fit into where the old controls went, and they look about the same.
Vintage air makes great stuff.
Old 05-03-2012, 12:16 AM
hairyboxnoogle
K ill take a look at it. I REALLY want to avoid having a AC switch and what not on the bottom of the dash like the dealer air... looks tacky, and i have it in the dash already anyway. Thanks for the help man, sounds hopeful. Im kinda scared to look tho, i might spot the price lol.
Old 05-04-2012, 12:08 AM
fordtrucknut's Avatar
fordtrucknut
fordtrucknut is offline
Let us know if the aftermarket one is the way you go...would love to hear how well it cools the cab...I want one for my 78 Crew Cab...but i'm leary of it not being able to cool the whole cab.
Old 05-04-2012, 12:27 AM
hairyboxnoogle
Actually the main reason i have been considering an aftermarket setup compared to stock is fords really werent known for their AC, sure its cold, but i breath more with every breath than my blower motor puts out on my way to work... As much as they cost, and as reputable as they are i figured that aftermarket would compare to a new vehicle, or better. My old boss has Classic Aire in his 61 belaire and it will freeze you out of that thing, and theyre pretty big inside, not to mention the cab is nothing but glass.
Old 05-04-2012, 12:49 AM
JB78f150's Avatar
JB78f150
JB78f150 is offline
Crsweet convinced me to do what he did then I can put a nice navigation stereo in. Thinking its the way to go and doesn't take up that much room. Also want a kit because it comes with everything.
Old 05-04-2012, 06:27 PM
hairyboxnoogle
Now that you mention it, a screen would be cool, but i think that might be a little too updated for this old truck, she'll be happy with 4 speakers and a sub im sure. Another thing i thought of and like.. if the aftermarket doesnt use vacuum then i can throw hydroboost on there and get rid of my vacuum pump altogether.
Alamo_cj8
05-12-2018 01:06 PM
JDBeck23
07-10-2015 03:52 PM
Chris79F350
06-02-2015 01:21 PM
shticky
01-28-2006 07:15 PM
nevyn
05-23-2003 02:03 PM
Quick Reply: Aftermarket AC ??'s
