Dash lights flickering, headlight switch clicking
Last night I pull on the headlight switch and no dash lights or gauge lights come on, then all the sudden they all start flickering and I can hear the headlight switch clicking on and off. With the truck running my voltage gauge was a little more than 14 v and whenever the lights would click on, the gauge would shoot down to 12.
Anyone ever have this happen? I'm assuming i just need a new headlight switch
the things rodents will do to your wires! When I got mine I had to re-run most of the wires and install tons of new switches because the PO left it outside and it was also a farm truck. Found my short to be a set of wires that a mouse chewed the casing off of so they were touching. Maybe the mouse ate it in my driveway, because I drove it home with aal the lights one month and the next month they were shorted. Then again, the drivers door switch for the dome light was stuck in the off position and shorting as well. Stupid racoons. And possums. And mice. And squirels. And chipmunks. And rats.
Have fun with that electricl issue!!
I've been tracing wires and can't find anything broken or exposed.
@jsutton, would it flicker even when sitting perfectly still, no wires bouncing around or anything?
Even with the truck parked sitting still, it still flickers and clicks. Replaced the headlight switch just because and the problem remains.
What year model are we talking about? If it's pre-77 you could have a wire shorting in the steering column. There isn't much room for the wiring in there and if it's not installed correctly and can wear and cause a short. Are the turn signals working? If not, I'd put my money on a short in the turn signal switch.
If you haven't replace a turn signal switch in a pre-77, come back and ask directions BEFORE you start pulling wires. There's an easy way and a hard way to do this. Easy is MUCH better. LOL
soulwinnerrj
Electrical Systems/Wiring
10-31-2007 07:55 PM
forwardcontrol1
03-29-2003 10:41 PM
