slave cylinder
<a href="http://s754.photobucket.com/albums/xx183/jaymeduty/?action=view&current=2012-03-31_16-04-42_274.jpg" target="_blank"><img src="http://i754.photobucket.com/albums/xx183/jaymeduty/2012-03-31_16-04-42_274.jpg" border="0" alt="Photobucket"></a>
so I got the darn thing it. now for the bleeding. last time i did this i was able to move the clutch fork by hand, push it in and hold it for a few seconds let out and it would suck fluid down it. I cannot move the fork at all. is that right or something wrong. what are other good bleeding ways, i know these can be a real pain.
the clutch fork was in wrong. i loosened all the tranny bolts took off the crossover and the cover on the bottom of the tranny. slid the tranny back about an inch and pulled the fork. got it back in correctly now and just have a hard time bleeding the system. any tips. last time i did it i just manually pushed and held the clutch fork and that is not working this time around. I have no pedal at all
When i replaced my clutch master i just filled it with fluid and started pumping the pedal by hand (have to pull it back up for the first while)... After doing that a while It started to build pedal and eventually it came back (better than before i might add).
I've heard before to pump it up til you can get the truck in gear then go drive it and the vibration will work the air up to the top. I just pumped it til it felt normal again.
Make sure to keep an eye on the fluid level and make sure you take the little rubber bladder out of the master before you pour in the fluid (did that in high school ).
I installed mine dry so it took a little bit of pumping...
i have tried all of the above and still nothing. when i get under the truck and crack the bleeder on the slave, push the clutch fork in by hand i get pure fluid coming out. i then close the bleeder and release the clutch fork. have done this probably close to a hunderd times and still no pedal at all.
well it is finally back together. Six inch prerunner kit from superlift up front, six inch BDS springs in the back with a 4 inch block. New Rancho Shocks, New clutch, new pressure plate, throw out bearing, pilot bearing and u-joints all the way around. New hardware for everything also. 315-75-16 fierce tires
before
<a href="http://s754.photobucket.com/albums/xx183/jaymeduty/?action=view&current=100_0747.jpg" target="_blank"><img src="http://i754.photobucket.com/albums/xx183/jaymeduty/100_0747.jpg" border="0" alt="Photobucket"></a>
after
<a href="http://s754.photobucket.com/albums/xx183/jaymeduty/?action=view&current=2012-04-16_12-59-10_332.jpg" target="_blank"><img src="http://i754.photobucket.com/albums/xx183/jaymeduty/2012-04-16_12-59-10_332.jpg" border="0" alt="Photobucket"></a>
before
after
cabloom300
02-09-2016 01:34 PM
Wolf82636
10-21-2010 03:12 PM
79_250RangerLariat
10-21-2007 08:00 PM
